Select Language:
Back To Top
EVGA GeForce GTX 980 HYBRID
Cooler than the Competition
Introducing the EVGA GeForce GTX 980 HYBRID, an "all-in-one" water cooling solution that significantly lowers the GPU operating temperature. Best of all? The water cooler is completely self-contained, with an included 120mm radiator and fan. No filling, no custom tubing, no maintenance. Just plug in and play! The EVGA GTX 980 HYBRID is available as a complete unit, or upgrade kit.
Of course, the GeForce GTX 980 HYBRID is also powered by the next-generation NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features. Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next-generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing.
Key Features
Also Available as Upgrade Kit
04G-P4-1989
  • 2048 CUDA Cores
  • Base Clock: 1291 MHz
  • Boost Clock: 1393 MHz
  • Bus: PCI-E 3.0
  • Memory Bit Width: 256 Bit
  • Memory Clock: 7010 MHz
  • Memory Speed: 0.28 ns
  • Memory Bandwidth: 224.3 GB/s
Key Features
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenGL 4.4 Support
  • OpenCL Support
  • PCI Express 3.0 x16
400-HY-H980
EVGA GeForce GTX 980 HYBRID (Cooler Only)
Key Features
  • All-in-one cooling solution that is completely self-contained. No filling, no custom tubing, no maintenance. Just plug and play.
  • Intelligent wiring system and sleeved tubing makes this one sleek cooler without the messy wires.
  • Copper base provides maximum heat transfer.
  • Variable controlled fans allow dynamic fan speed based on GPU temperature, and the water cooling efficiency means very low noise fans.
  • Built-in 120mm radiator and fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customised.
  • Compatible with all "reference" GeForce GTX 980 graphics cards.
  • VRM and Memory cooling solution separated from GPU, allowing for the lowest GPU temperatures, and efficient VRM and Memory cooling.
Key Features
  • Temperature Target Control
  • Pixel Clock Overclocking
  • Robust monitoring allowing ingame, system tray and/or Logitech LCD monitoring
  • In game screenshot hotkey, supports BMP, PNG and JPG formats
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 HYBRID vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
Launch OC Scanner Site
