Nothing Beats Titanium
EVGA SuperNOVA 1000, 850 and 750 T2 Power Supplies
The unmatched efficiency and performance of EVGA SuperNOVA T2 power supplies are now available in 1000, 850 and 750 watt formats. These units feature an unbelievable 96%+ efficiency, along with EVGA ECO mode to deliver absolutely zero fan noise during low to medium load operations. Backed by an award winning 10 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA T2 series deliver unbeatable performance.
96% efficiency or higher under typical loads and highest quality Japanese brand capacitors ensure long-term reliability.
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
FULL modularity enables you to use only the cables you need helping to improve case airflow, eliminate unnecessary wires, and best of all, reduce cable clutter.
220-T2-1000
EVGA SuperNOVA 1000 T2
Features
  • Highest quality Japanese brand capacitors ensure long-term reliability
  • Ultra Quiet Fan with ECO Intelligent Thermal Control Fan system (Zero Fan Noise < 45°C)
  • 80 PLUS Titanium certified, with 94% (115VAC) / 96% (220VAC~240VAC) efficiency or higher under typical loads
Specs
  • OPP (Over Power Protection)
AC Input 100 - 240 VAC, 15A, 50 - 60 Hz
DC Output +3.3V +5V +12V +5Vsb -12V
MAX Output 20A 20A 83.3A 2.5A 0.5A
83.3A
Combined 100W 999.6W 12.5W 6W
Output Power 1000W @ +50C
220-T2-0850
EVGA SuperNOVA 850 T2
Features
Specs
AC Input 100 - 240 VAC, 10A, 50 - 60 Hz
MAX Output 20A 20A 70.8A 2.5A 0.5A
70.8A
Combined 100W 849.6W 12.5W 6W
Output Power 850W @ +50C
220-T2-0750
EVGA SuperNOVA 750 T2
Features
Specs
MAX Output 20A 20A 62.4A 2.5A 0.5A
62.4A
Combined 100W 748.8W 12.5W 6W
Output Power 750W @ +50C
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA 1000 T2 provides up to 83.3A respectively on a single rail.
Full DC to DC, LLC resonant circuit design improves efficiency.
Fully modular design allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The SuperNOVA T2 series gives you the power you need to drive these demanding systems and achieve the best overclocks.
80 Plus Titanium certification ensures your power supply isn’t wasting power and Turning it into excess heat. Under typical load this power supply is 96% efficient or higher.
