Select Language:
Back To Top
EVGA GeForce GTX 1070 ACX 3.0 EVGA GeForce GTX 1070 ACX 3.0 Card Precision XOC VR Ready
The EVGA GeForce GTX 1070 featuring EVGA ACX 3.0 cooling is here. This new graphics card features NVIDIA’s new “Pascal” graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
These cards also feature EVGA ACX 3.0 cooling technology. EVGA ACX 3.0 once again brings new and exciting features to the award winning EVGA ACX cooling technology. SHP 3.0 gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX 3.0 coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU. Select EVGA ACX 3.0 models will even feature a 10CM fan and RGB LED, allowing complete control over the color from EVGA Precision XOC.
Standard Overclock Mode
Pascal Linear
Pascal Manual
Built In Automatic Tuning
Adjustable RGB LED
* Available on select models
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum “power target” takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 3.0 coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
8GB of high performance memory running at extreme Clockspeeds giving you access to higher texture qualities in games and improved 4K gaming performance. Did we mention that this memory is running at an extreme 8,000MHz out of the box??!!
08G-P4-6276
EVGA GeForce GTX 1070 FTW GAMING ACX 3.0
  • 1920 CUDA Cores
  • Base Clock: 1607 MHz
  • Boost Clock: 1797 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
  • Memory Detail: 8192 MB GDDR5
  • Memory Bit Width: 256 Bit
  • Memory Clock: 8008 MHz
  • Memory Speed: 0.25 ns
  • Memory Bandwidth: 256.3 GB/s
Key Features
  • EVGA Double BIOS
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12
  • Vulkan API
  • OpenGL 4.5 Support
  • PCI Express 3.0
  • EVGA ACX 3.0 Cooling
  • 10 Phase Power Design
  • Adjustable RGB LED
08G-P4-6173
EVGA GeForce GTX 1070 SC GAMING ACX 3.0
  • 1920 CUDA Cores
  • Base Clock: 1594 MHz
  • Boost Clock: 1784 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
08G-P4-6171
EVGA GeForce GTX 1070 GAMING ACX 3.0
  • 1920 CUDA Cores
  • Base Clock: 1506 MHz
  • Boost Clock: 1683 MHz
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
08G-P4-6170
EVGA GeForce GTX 1070 FOUNDERS EDITION
  • 1920 CUDA Cores
  • Bus: PCI-E 3.0
  • 2-way SLI Ready
  • Memory Clock: 8000 MHz
  • Memory Bandwidth: 256 GB/s
Key Features
  • VR Ready
  • NVIDIA Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • PCI Express 3.0
EVGA GeForce GTX 1070 Comparison Chart
