Built For The Win
Introducing the EVGA GeForce GTX 980 Ti FTW. Accelerated by the groundbreaking NVIDIA Maxwell architecture, the EVGA GeForce GTX 980 Ti FTW ups the game with dual 8-Pin Power inputs, 8+2 Phase Power Design, Dual BIOSes and an included EVGA backplate. Not to mention this card packs 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, giving you the horsepower to drive whatever comes next. In fact, the EVGA GeForce GTX 980 Ti FTW provides over 3x the performance and 3x the memory of previous-generation cards*.
This card also features EVGA ACX 2.0+ cooling technology. EVGA ACX 2.0+ brings new features to the award winning EVGA ACX 2.0 cooling technology. A memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 13%, and optimized Straight Heat Pipes (SHP) additionally reduce GPU temperature by 5C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*GeForce GTX 680
Built for Overclocking with an Extra +25W of Power
Remark:
* Versus Competitors' Dual Fan Solution. ** When GPU Temperature < 60°C *** Versus Reference Fan
EVGA's ACX 2.0+ fan turns off below 60°C, generating 0dB of noise.
Multiple integrated BIOSes allow you to switch to the secondary with the flick of a switch.
Full size cooling plate makes direct contact with memory and MOSFETs, reducing memory up to 9°C and MOSFET up to 11°C.
The power target is precisely tuned for the perfect balance of thermal, power and performance, offering 33% more power over reference.
Triple 8mm straight heat pipes offer 6% better heat dissipation than bent heat pipes with reduced thermal resistance.
6GB of High Performance memory running at extreme clockspeeds giving you access to higher texture qualities in games, improved 4K gaming performance and optimized for the next generation of gaming.
Introducing EVGA PrecisionX 16 version 5.3.5 with full support for Microsoft DirectX 12 OSD support. This latest version of EVGA PrecisionX adds new features, overclocking support, functionality, and full support for the upcoming Microsoft DirectX 12 API. Download it for free today!
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 Ti FTW vitals. Learn more and download it here.
