Cooler than the Competition
The Award Winning EVGA HYBRID line is now available on GeForce GTX 970. The EVGA GeForce GTX 970 HYBRID GAMING is an “all in one” water cooling solution that significantly lowers the GPU operating temperature. Best of all? The water cooler is completely self-contained, with an included 120mm radiator and fan. No filling, no custom tubing, no maintenance. Just plug in and play!
Of course, the GeForce GTX 970 HYBRID GAMING is also powered by the next-generation NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features. Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next-generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing.
04G-P4-1976
Key Features
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenGL 4.4 Support
  • OpenCL Support
  • PCI Express 3.0 x16
  • 1664 CUDA Cores
  • Base Clock: 1140 MHz
  • Boost Clock: 1279 MHz
  • Bus: PCIe 3.0
  • 2-way, 3-way SLI Ready
  • Memory Bit Width: 256 Bit
  • Memory Clock: 7010 MHz
  • Memory Speed: 0.28 ns
  • Memory Bandwidth: 224.3 GB/s
EVGA PrecisionX – Redesigned to harness the power of GPU Boost 2.0, EVGA PrecisionX sets another baseline for what overclocking software should be. Learn more and download it here.
Key Features
  • Temperature Target Control
  • Pixel Clock Overclocking
  • Robust monitoring allowing ingame, system tray and/or Logitech LCD monitoring
  • In game screenshot hotkey, supports BMP, PNG and JPG formats
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 970 HYBRID GAMING vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
