Select Language:
EVGA iCX Technology is not JUST a Cooler.
It is a combination of new PCB, Thermal Modules, LED, and Precision XOC.
  • Featuring a total of 11 global patents (pending and granted), iCX is efficiency perfected.
  • 9 Additional Sensors and MCU's embedded on the PCB.
  • Purposefully-directed Airflow Chambers.
  • Newly Designed Die-Cast Baseplate and Backplate.
  • Full Control Using EVGA Precision XOC.
  • EVGA's iCX is the Very Definition of Interactive Cooling.
Why was iCX created?
After the ACX 3.0 cooler was verified to operate within spec on Power and Memory section from independent third party testing, we determined that on an enthusiast graphics card, one thermal sensor is just not enough. On an enthusiast graphics card, equal importance should be given to the Power and Memory, not just focused on GPU. This type of thinking required drastic change in the way thermal management is performed on a graphics card.
With EVGA iCX Technology, a new era of PC gaming is coming!
iCX Has 9 Thermals Sensors & Multiple MCUs
All 9 sensors can be displayed in EVGA Precision XOC and OSD
Asynchronous Fan Control
A new & more efficient way to cool
GPU fan determined by GPU temperature (Left Fan)
Power / Memory fan determined by Power / Memory temperature (Middle / Right Fan)
EVGA iCX Is The BEST Dual Slot Air Cooler
EVGA iCX's efficient design means it can keep a Dual Slot size allowing more room for other expansion cards, improved chassis compatibility, and improved compatibility with SLI.
Full Control with EVGA Precision XOC
Each sensor can be monitored in real time and displayed in PXOC OSD.
Control the VGA/Power fans simultaneously or asynchronously.
Interactive cooling with Thermal Display System
User customized RGB color and visual alarm settings*
Peace of Mind Gaming
An EVGA only fuse adds another layer of protection to your card and system.
Optimized airflow fin design
An optimized air flow design directs air through the fin holes, while half open fins maximize airflow to important components and L-shaped fins increase surface contact.
Interlaced pin fin on Baseplate
Diecast form fitted baseplate and backplate
Backplate makes direct contact with all vital components and new baseplate design with integrated heatpipe significantly reduces component temperatures
Play longer! Overclock Better!
Interaction with Other Devices*
11G-P4-6797-K1
EVGA GeForce GTX 1080 Ti FTW3 ELITE White
  • CUDA Cores: 3584
  • Base Clock: 1569 MHz
  • Boost Clock: 1683 MHz
  • Bus: PCIe 3.0
  • SLI Support: 2-way
  • Type: GDDR5X
  • Width: 352 Bit
  • Clock: 12006 MHz
  • Speed: 0.17 ns
  • Bandwidth: 528.3 GB/s
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12 API
  • Vulkan API
  • OpenGL 4.6 Support
  • Asynchronous Fans
  • 9 additional temp sensors to monitor Memory and VRM
  • GPU / Memory / PWM Thermal Status Indicator LEDs
  • New vented heatsink fin design and pin fins for optimized airflow
  • Safety fuse to protect components from damage due to improper installation or other component failures
  • Redesigned cooling with L-shaped contact fins to improve contact surface area for better heat dissipation
  • EVGA iCX Technology
11G-P4-6797-K2
EVGA GeForce GTX 1080 Ti FTW3 ELITE Black
  • CUDA Cores: 3584
  • Bus: PCIe 3.0
  • Type: GDDR5X
  • Width: 352 Bit
  • Clock: 12006 MHz
  • Speed: 0.17 ns
Key Features
  • VR Ready
  • NVIDIA® Ansel
  • NVIDIA G-SYNC
  • NVIDIA GameStream
  • Vulkan API
  • Asynchronous Fans
* Coming Soon
