Overclocking Perfection
The EVGA GeForce GTX 980 K|NGP|N graphics card is meticulously designed for the extreme overclocker. With a 14+3 power phase design, this new digitally controlled VRM can deliver up to 600A of current, all delivered through 3 power inputs, 8pin + 8pin + 6pin. ACX 2.0+ keeps the card running cool, and the ability to go single slot, with the included single slot bracket, makes this one of the sleekest graphic cards designed to date.
Vince "K|NGP|N" Lucido is an extreme overclocker who has achieved many 3DMark World Records with EVGA hardware. He contributed to the design of the GTX 980 K|NGP|N Edition graphics card with EVGA, and had this to say:
"The power designs for both the GPU and memory on the EVGA GeForce GTX 980 K|NGP|N graphics card should allow some insane overclocking and some of the highest clockspeeds seen to date. Also, with the new multi-color LED cooler, you can customise the look of the card to fit any system."
Full colour control allows you to fine tune the color to your liking using EVGA PrecisionX!
When we say this card offers unbelievable overclocking, we mean it. Vince “K|NGP|N” Lucido was able to take the GeForce GTX 980 GPU to new heights at over 2200MHz GPU clock and 8900MHz memory clock on Liquid Nitrogen Cooling.
EVGA ACX 2.0+ fans use double ball bearings, which offer 400% longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in Sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX 2.0+ and your card will go the distance!
EVGA GeForce GTX 980 K|NGP|N ACX 2.0+
- 2048 CUDA Cores
- Base Clock: 1304 MHz
- Boost Clock: 1418 MHz
- Memory Detail: 4096 MB
- Memory Bit Width: 256 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- NVIDIA MFAA Technology
- NVIDIA GameWorks Technology
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 2.0
- NVIDIA Surround Technology
- NVIDIA SLI Ready
- OpenGL 4.4 Support
- OpenCL Support
- PCI Express 3.0 x16
- EVGA ACX 2.0 Cooling
- Quick Switch Dual BIOS
- dB Inverter
- Memory MOSFET Cooling Plate
- Optimized Power Target
- Straight Heat Pipes
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 960 vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
