![](https://www.evga.com/articles/00914/images/back_to_top_arrow.png)
![EVGA GeForce GTX 960 4GB](https://www.evga.com/articles/00914/images/header/Header-Text.png)
![EVGA GeForce GTX 960 4GB Card](https://www.evga.com/articles/00914/images/header/product-image.png)
Now Available With 4GB of GDDR5 Memory
The EVGA GeForce GTX 960 delivers incredible performance, power efficiency, and gaming technologies that only NVIDIA Maxwell technology can offer. This is the perfect upgrade, offering 60% faster performance and twice the power efficiency of previous generation cards*. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC technology, and Dynamic Super Resolution for 4K-quality gaming on 1080P displays. The latest versions come outfitted with 4GB of high speed GDDR5 memory giving you higher texture qualities and better 4K performance!
The new EVGA ACX 2.0+ cooler brings new features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 11°C, and optimised Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimised swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*Compared to GTX 660
EVGA ACX 2.0+ Cooling
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
![EVGA GeForce GTX 960 4GB Cooling Chart](https://www.evga.com/articles/00914/images/cooling/Cooling-Image.png)
![](https://www.evga.com/articles/00914/images/features/Slogan.png)
Why Double Ball Bearings?
![](https://www.evga.com/articles/00914/images/bearings/Ball-Bearing-Image.png)
Built with 4GB of High Performance GDDR5 Memory
4GB of High Performance Memory running at over 7,000MHz giving you higher texture qualities in games, better 4K gaming performance and optimised for the next generation of gaming.
EVGA ACX 2.0+ Means Better Overclocking
![](https://www.evga.com/articles/00914/images/overclocking/087.png)
![](https://www.evga.com/articles/00914/images/overclocking/088.png)
![](https://www.evga.com/articles/00914/images/overclocking/382.png)
![](https://www.evga.com/articles/00914/images/overclocking/383.png)
![](https://www.evga.com/articles/00914/images/overclocking/Over-4X.png)
- 1024 CUDA Cores
- Base Clock: 1304 MHz
- Boost Clock: 1367 MHz
- 2-way SLI Ready
- Memory Bit Width: 128 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- EVGA Backplate
- NVIDIA MFAA Technology
- NVIDIA GameWorks Technology
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 2.0
- NVIDIA Surround Technology
- NVIDIA SLI Ready
- OpenGL 4.4 Support
- OpenCL Support
- PCI Express 3.0 x16
- EVGA ACX 2.0 Cooling
- Quick Switch Dual BIOS
- dB Inverter
- Memory MOSFET Cooling Plate
- Optimized Power Target
- Straight Heat Pipes
- 1024 CUDA Cores
- Base Clock: 1279 MHz
- Boost Clock: 1342 MHz
- 2-way SLI Ready
Key Features
- EVGA Backplate
- NVIDIA SLI Ready
- OpenCL Support
- dB Inverter
- 1024 CUDA Cores
- Base Clock: 1127 MHz
- Boost Clock: 1178 MHz
- 2-way SLI Ready
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- dB Inverter
EVGA GeForce GTX 960 Comparison Chart
![](https://www.evga.com/articles/00914/images/products/Comparison-Chart.png)
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 960 vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
