EVGA 1000, 850, 750 and 650 GQ Power Supplies
Introducing the ultimate value in the EVGA Power Supply lineup; the GQ series. These power supplies take some of the best features from EVGA’s award winning power supply lineup, like EVGA ECO fan mode for near silent operation, Japanese Capacitors, and a highly efficient design, at an excellent value. These new power supplies are 80 Plus Gold rated and offer an outstanding 5 Year Warranty that’s backed by world class EVGA support.
90% efficiency or higher under typical loads and 100% of the highest quality Japanese brand capacitors ensure long-term reliability.
Features
- Modular Design to reduce clutter and improve airflow
- Active Clamp +DC to DC design for efficient operation
Specs
- OPP (Over Power Protection)
AC Input | 100 - 240 VAC, 16A, 50 - 60 Hz | ||||
DC Output | +3.3V | +5V | +12V | +5Vsb | -12V |
MAX Output | 24A | 24A | 83.3A | 3A | 0.5A |
83.3A | |||||
Combined | 120W | 999.6W | 15W | 6W | |
Output Power | 1000W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 14A, 50 - 60 Hz | ||||
MAX Output | 24A | 24A | 70.8A | 3A | 0.5A |
849.6W | |||||
Combined | 120W | 849.6W | 15W | 6W | |
Output Power | 850W @ +50C |
Features
Specs
MAX Output | 24A | 24A | 62.4A | 3A | 0.5A |
748.8W | |||||
Combined | 120W | 748.8W | 15W | 6W | |
Output Power | 750W @ +50C |
Features
Specs
MAX Output | 24A | 24A | 54A | 3A | 0.5A |
648W | |||||
Combined | 120W | 648W | 15W | 6W | |
Output Power | 650W @ +50C |
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA 1000 GQ can provide up to 83.3A on the +12V rail!
Active Clamp SR+DD Circuit Layout. Full DC to DC Active Clamp circuit design improves efficiency.
Modular design allows some cables to be removed from the power supply for ease of installation and removal. You can leave off unnecessary cables to reduce case clutter and maximize case airflow.
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The EVGA GQ gives you the power you need to drive these demanding systems and achieve the best overclocks.
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical loads these power supplies are 90% efficiency or higher.
