Select Language:
EVGA G2L Series
EVGA SuperNOVA 850 and 750 G2L Power Supplies
The unbeatable performance of the EVGA SuperNOVA G2 power supply line is now available with LED lighting in the new G2L versions. These units feature 80 Plus Gold rate efficiency, and clean continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low to medium load operations. Backed by an award winning 10 Year Warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 850/750 G2L power supplies offer unbeatable performance at an unbeatable value.
EVGA SuperNOVA 850 G2L
220-GL-0850
Features
  • Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
  • Highest quality Japanese brand capacitors ensure long-term reliability
  • Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
  • Built in White LEDs
Specs
  • OPP (Over Power Protection)
AC Input 100 - 240 VAC, 10A, 50 - 60 Hz
DC Output +3.3V +5V +12V +5Vsb -12V
MAX Output 24A 24A 70.8A 3.0A 0.5A
849.6W
Combined 120W 849.6W 15W 6W
Output Power 850W @ +50C
220-GL-0750
EVGA SuperNOVA 750 G2L
Features
Specs
MAX Output 24A 24A 62.4A 3.0A 0.5A
748.8W
Combined 120W 748.8W 15W 6W
Output Power 750W @ +50C
Built in LED
Illumination
Killer performance, killer looks with built in White LED Illumination.
Build-In LED Illumination
100% Modular Design
FULL modularity enables you to use only the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all, reduce cable clutter.
100% Modular Design
Whisper Silent
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
Unbeatable Performance
90% efficiency or higher under typical loads and highest quality Japanese brand capacitors ensure long-term reliability.
Features
Single +12V Rail
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA 850/750 G2L provides up to 70.8A/62.4A respectively on a single rail!
LLC Resonant Circuit Layout
Full DC to DC, LLC resonant circuit design improves efficiency.
Fully Modular
Fully modular design allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
NVIDIA SLI Ready
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The SuperNOVA 850/750 G2L gives you the power you need to drive these demanding systems and achieve the best overclocks.
Highest Quality Japanese Nippon Chemi-Con Capacitors
Gold Rated Efficiency
80 Plus certification ensures your power supply isn’t wasting power and turning it into excess heat. Under typical load this power supply is 90% efficient or higher.
