Engineered for the Enthusiast
EVGA welcomes you to the next generation of ground-breaking performance: the X99 FTW K! The X99 platform redefines high-performance with the introduction of the first ever quad-channel DDR4 architecture fueled by Intel’s Haswell-E/Broadwell-E CPU family for up to 128GBs of RAM running at a maximum memory speed of up to 3200MHz+ (OC), all made possible due to the 4-layer memory T-Routing design. The X99 FTW-K is built with an 8-layer Hybrid Black PCB, featuring a CPU socket with 150% higher Gold content powered by an Advanced 8-phase Digital VRM (IR3563B+IR3350), providing industry-leading stability for all your applications.
This board also features a Killer NIC E2400 Ethernet which helps to prioritize and reduce network latency to keep you at the top of your game.
Furthermore, this board is designed not ONLY for peak overclocking, but also fully-featured to support any/all peripherals and functions available, 4-Way SLI support, 2 Gigabit LAN, right-angle power connectors, PCI-E disable switches and much more!
Killer™ E2400 NIC
Built in Killer Ethernet helps to prioritize and reduce network latency to keep you at the top of your game.
Integrated USB 3.1
Type-C and Type-A
Get your PC future proof ready with the EVGA X99 FTW K motherboard. This motherboard features the next generation USB 3.1 Type-C connector that delivers transfer speeds of up to 10Gb/s for unbelievable performance.
X99 Platform
Intel® X99 Platform Unlocks Incredible Performance
Intel® X99 Chipset
- Supports up to 20 CPU threads (10-core)
- First desktop platform to support DDR4 RAM
- Up to 40 PCI-E 3.0 lanes
- Native SATA 6.0Gb/s, USB 3.0, and USB 3.1
- Up to 25MB CPU Cache on 10 core CPU
Intel® Core™ i7-5960X vs. Intel® Core™ i7 4960X
- Game Physics and AI up to 14% FASTER (3DMark Fire Strike Physics Extreme)
- 4K Video Editing up to 20% FASTER (Adobe Premiere Pro CC)
- 3D Rendering up to 32% FASTER (CINEBENCH 15 X)
Intel® Core™ i7-5960X vs. Intel® Core™ i7 4790K
- Multithreaded Performance up to 79% FASTER (SPECint*_rate_base2006)
- 4k to 1080p Transcoding up to 69% FASTER (Handbrake)
EVGA X99 FTW K Motherboard
Part Number: 151-BE-E097-KR
Specifications
- Chipset – Intel® X99 Express
- SLI – Up to 4-Way SLI
- SATA – 10 Native SATA 6.0Gb/s Ports
- USB – 2 USB 3.1 (1 Type-C, 1 Type-A) / 8 Native USB 3.0 / 8 USB 2.0
- Memory – 8 DIMM Quad-Channel DDR4 3200MHz+ (OC) (Up to 128GB)
- Capacitors – 100% Solid State
- Form Factor – E-ATX
- Ethernet – Intel® Gigabit NIC, Killer Gigabit NIC
- Audio – 8 Channel High Definition Audio + Optical
- M.2 Socket M Support 32Gbps
- PCB – 8 Layers
Features
- Highly Efficient 8-Phase Digital VRM
- Onboard Power, Reset and Clear CMOS
- EVGA E-LEET X Tuning Utility
- Onboard CPU Temp Monitor
- Black Nickel CPU ILM
- Built in USB 3.1 Type-C Port
- Audio Isolation for Superior Sound
External I/O
- 4x USB 2.0
- 4x USB 3.0
- 1x USB 3.1 Type-C, 1x USB 3.1 Type-A
- 2x Gigabyte LAN
- 8 Channel Audio + Optical
Internal I/O
- 2x USB 2.0 Header (4 Ports)
- 2x USB 3.0 Header (4 Ports)
- 10x SATA3/6G Ports
Features
Brand New GUI BIOS Interface
PCI-E Disable Switch
Dual BIOS Support
Right Angle 24 PIN
Includes M.2 Support
EZ Voltage Read Points
Passive Chipset Heatsink
8 PIN CPU Power
8 Phase PWM
8 Layer PCB
Higher Gold Content
Killer E2400 NIC
