Asynchronous
Fan Control
A New and More
Efficient
Way to Cool
GPU fan determined by GPU temperature (Left Fan)
Power / Memory fan determined by Power / Memory temperature (Right Fan)
Full Control With
EVGA Precision XOC
Each sensor can be monitored in real time and displayed on PXOC OSD
Control the VGA and Power/Memory fans simultaneously or asynchronously
Interactive
Cooling With
Thermal LED Display System
User customized RGB color and visual alarm settings*
PeaceOfMind
Gaming
An EVGA ONLY fuse adds another layer of protection to your card and system.
Optimized Airflow
Fin Design
Fin holes direct airflow through fins
Half open fin maximizes airflow and L-shaped fins increase surface contact
Die Cast
Form Fitted Baseplate
And Backplate
Makes direct contact with all vital components.
Interlaced Pin Fin on Baseplate
Play Longer!
Overclock Better!
Interaction with other system devices*
* Coming SoonEVGA GeForce GTX 1080 with iCX Technology
- 2560 CUDA Cores
- Base Clock: 1721 MHz
- Boost Clock: 1860 MHz
- 2-way SLI Ready
- Memory Bit Width: 256 Bit
- Memory Clock: 10010 MHz
- Memory Speed: 0.18 ns
- Memory Bandwidth: 320 GB/s
Key Features
- EVGA Double BIOS
- VR Ready
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- Microsoft DirectX 12 API
- Vulkan API
- OpenGL 4.6 Support
- 10 Phase Power Design
- Adjustable RGB LED
- Asynchronous Fans
- EVGA iCX Technology
- 2560 CUDA Cores
- Base Clock: 1708 MHz
- Boost Clock: 1847 MHz
- 2-way SLI Ready
Key Features
- VR Ready
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- Vulkan API
- Asynchronous Fans
