Header
Lifelike Audio
Improved and Expanded Features
Header
  • Lifewire
  • NikKTech.com
  • Funky Kit
  • TechPowerUp
  • BadSeed Tech
Bring your next-gen system, to the next generation of premium audio.
For nearly 20 years, EVGA has built the most powerful graphics cards to play your games at the highest settings, powerful motherboards to run your system at optimal settings, and reliably efficient power supplies to power your system. Now, EVGA extends its enthusiast tradition by partnering with Audio Note (UK), Ltd. to provide the most immersive audio and lifelike gaming experienced on a PC with EVGA NU Audio Card.
header image
gallery_01_AN_capacitors
Audio Note (UK), Ltd. Audio-Grade Capacitors
Exclusive Components by Audio Note (UK), Ltd.
Audio Note (UK), Ltd. Audio-Grade Resistors
Engineered by Audio Note (UK), Ltd.
Audio Note (UK), Ltd. has been in the high-end audio business for over 30 years, making a name for itself by producing a wide variety of analog and digital devices. A core component of Audio Note's philosophy is to research, design, and build its own components - often custom-made for the specific application - without financial limitations to create the finest audio products available. With this in mind, EVGA partnered with Audio Note (UK), Ltd. to select audiophile-grade digital and analog components and carefully craft the NU Audio card.
Click here to learn more about Audio Note (UK), Ltd.
True Audio
Hear everything
"Hear music the way the artist wants you to hear it."
This is a common refrain to describe audio equipment. Instead, the NU Audio card simplifies the matter - hear audio as it is.
Lifelike Gaming
The right gear for the game.
Engineered by Audio Note means a lower measured and perceived noise floor to improve enemy detection, and precise enemy location due to improved transient and phase response. The NU Audio Card is NOW powered by nahimic with 3D Audio for Gamers, featuring virtual surround to enhance positioning, smart volume to limit volume fluctuation, and ambient noise suppression to play with confidence knowing that you will be heard clearly-in game.
Studio and Audiophile Grade
Finely-tuned fun.
Enjoy movies, produce music, record podcast, or simply experience great audio. Hear all the subtle sounds, emotional dialog, and powerful explosions to keep you on the edge of your seat without the need to browse through confusing menus. With recording performance up to 384kHz, 32bit, you can speak the way you want to be heard. After all, only you should sound like you.
Ambient RGB Lighting
The NU Audio Card enhances the relationship to music and mood. Change the 10-Mode RGB to match your favorite color, or use any of the four Audio Reactive Lighting options to let your audio set the tone and color of the NU Audio Card lighting. Alternatively, simply turn the RGB off if you'd prefer to keep things dark.
A completely different gaming and multimedia experience
High-quality audio is built on a simple premise: everything must be solid from start to finish. One weak link in the chain can turn a symphony into a cacophony. The NU Audio card features a high-performance digital section with Native DSD support and a clean, powerful analog section. This audio quality carries over to other applications, such as gaming, where the ability to clearly identify the difference between ambient environment noise and a stealthy enemy can be the difference between life or death.
panels
panels
Details Matter
Even the smallest details were not left to chance as the NU Audio card contains a variety of output/input options, switchable OP-AMPs, copper shielding, a passive heatsink, gold-plated PCB, and 10-mode RGB audio reactive lighting controllable through the EVGA NU Audio software.
gallery_02_xmos
XMOS xCORE-200 DSP
gallery_02_op_amp
Switchable OP-AMPs
gallery_02_heatsink
Passive Heatsink Copper Shielding
gallery_02_heatsink
Maxim Independent Headphone Amp Analog Volume Control
Software
Premium audio deserves straight forward software
The NU Audio software avoids the clutter of features that you never use. Simple volume and mute controls are right at your fingertips once you open the software. Digital processing options, including virtual surround, are neatly lined-up across the bottom.
Nu Audio Software
Use the Quick three-slider EQ menu to tune your audio, or go Advanced and set profiles with a full 10-band EQ bar. Customizable audio reactive RBG lighting lets your music choose how your card looks from moment-to-moment.
Hear the Difference
Click below to sample hi-fidelity audio tracks with your EVGA NU Audio Card.
Coming Soon
P/N: 712-P1-AN01-KR
Specifications:
    Audio DSP:
  • XMOS xCORE-200
  • Native DSD Support (up to x256)
    Output Configuration:
  • 2 Channel (Analog)
  • 5.1 Channel (Digital via S/PDIF)
    Dynamic Range (DNR) / Signal-to-Noise (SNR):
  • 123dB (Stereo Playback)
  • 121dB (Line-In Recording)
    Playback Format:
  • Up to 384kHz, 32bit (Stereo)
  • Up to 192kHz, 24bit (Optical)
    Headphone Amp:
  • 16-600ohm (Independent Analog Control)
    Maximum Voltage:
  • 8Vrms
    Maximum Current:
  • 250mA
    Recording Format:
  • Up to 384kHz, 32bit (Line-In)
  • Up to 192kHz, 24bit (Mic-In)
    RGB Lighting:
  • 10 - Mode w/ Audio Reactive Lighting
    I/O:
  • Stereo Out (RCA L/R)
  • Headphone Out (6.3mm)
  • Line-In (3.5mm)
  • Mic-In (3.5mm)
  • Optical Out (TOSLINK Passthrough)
  • Front Panel Header
    Premium Components:
  • DAC - AKM AK4493
  • ADC - AKM AK5572
  • OP-AMP (Headphone) - ADI OP275
  • OP-AMP (Line Out) - ADI AD8056
  • Capacitors - WIMA, Audio Note(UK), Nichicon
  • Power Regulators - Texas Instruments TPS7A47/TPS7A33 ultralow-noise power solution
    Switchable OP-AMPs:
  • Headphone, Line out
    Interface:
  • PCIe x1 Gen2
    Power Connector:
  • 1x SATA Power
    Supported OS:
  • Windows 10 (64-bit)
header image
